Engine shake
jc971
Guadeloupe 971
Hello
my e9 is finally running
almost everything works but there is still a lot of work
on the other hand I find that my m30b35 engine with the weber moves a lot, it runs well
I have the impression that my engine and gearbox mounts are too flexible
Have you ever had this problem ?
it shakes a little when stopped but especially when I make a maneuver, for example reverse
And my cabs are sync
timing set correctly? just curious, but doesn't the b35 control timing with motronics? if you have carbs, you aren't using the ecu ... what have you done for timing control?
