westoz3.0csa
G'Day All,
I have come into possession of a complete (from Flywheel to fan) M30B30 from a '94 Euro E32 730i (60K miles).
I was able to hear the motor running and do compression test (180-185 PSI on all cylinders)
I was just going to use it as a parts motor and swap out the FI to my
carbed motor .. but .. I have decided the better confused option is to just do a complete swap and store the original motor.
I would like to avoid any problems or surprises .. so .. my queries are ...
1) Will this motor bolt straight in, as is ? If not what do I need ?
2) Anybody that may have done this or similar swap (M30B35? from
similar era) got any tips or advice ?
3) Is there anything you would recommend I should do to the motor
before I swap it in ? ie: seals, bearing etc
4) What fuel pump could I use or is recommended ? ie, whats fits my
tank ?
As always any advice is greatly appreciated
Carl
'74 3.0CSA
tank ?
Carl
'74 3.0CSA
