Entire Dash SOLD
DavidE9
Alberta Canada
Yup, Entire dash assembly including gauges. Pics show best! Top part isn't cracked but slightly crumpled in one corner and a little rusty. Guage hood has a small crack and fading. Middle part is actually quite nice other than some moisture damage in the passenger side. Dash bar is cracked by the glove box button otherwise in nice shape!
SOLD
Located by Calgary Alberta Canada
do you happen to have any lower dash pieces? like under the steering wheel etc etc
$1,500 is a deal. Please sell it to someone who actually needs a dash, not someone looking to throw it on ebay.
@posix, when looking for dash pieces, please be aware that there are some differences between models - it pays to be specific on what you are looking for
top dash panel - the 2800cs / early 3.0cs did not have a seatbelt warning light - most 3.0cs did
lower dash panel - later 3.0cs automatics had the automatic indicator light mounted on the lower dash
grab rail - 2800cs is different than all 3.0cs - in the 3.0cs there is a place for the emergency flasher
grab rail trim - 2800cs / early 3.0cs had a single piece trim ... 74 model had 2 piece trim because of extending steering wheel < i might have this backward >
gloveboxes (both sides) - 74 models (maybe late 73) had a twist knob rather than the push button
under steering panel - 74 was different shape due to extending steering column.
@DavidE9 - questions
this appears to come from a 72 / 73 - 3.0cs. you can probably verify (if you don't know by looking at the dates on back of gauges)
wood
- what is the condition of the bottom wood piece of the dash? in particular the mounting bolts, do they spin or are the bolts still secure
- on the curved portions, it would be helpful to share pictures of any wood delamination to determine the severity / ability to repair.
guages
- any idea if they work / don't work? shame the speedo has a big kink in the bezel
top dash
- has the foam disintegrated on the passenger side where it is deformed.
color fading can be solved by repainting with SEM color coat (satin black). small cracks can be filled with glazing putty. the bigger issue on the top dash ???
value - first thought might be a little high, but that depends on how solid the wood is and if the gauges work. if all is good, reasonable.
BUMP! Parting the dash out
questions asked remain unanswered
wood
guages
top dash
wood
guages
top dash
It is out of a 73 3.0cs North American spec. I'll get some more pictures of the wood. No idea if the gauges work but they were stored nicely and well I would be surprised if they didn't. Clock likely doesn't work.
You realize shipping will be ridiculous?
Do you need it priority mail?
I’d like a bottle of decent wine for a trade please.
Not only is the cost of shipping ridiculous, ( what has happened here, $15 to send a letter?? ), it takes a month or more to receive it.
Trained dolphins would deliver it quicker and cheaper, they'll do anything for a few herring. The dolphin will bring back the bottle - just be sure to give it a pat on the nose, they like that.
