MOT's
My CSi is back legal and on the road again.
A friend did the little weld. Tidy job - welded a wee plate, grinder to tidy the joins, then liberal coatings of seam sealer and then underseal.
We then freed off the sticky brake caliper, fitted new pads ( glad I bought a set of rears by mistake as one of my last ebay purchases - karma ).
The handbrake has always been crap on my car, with the pin that goes through the lever and the mounts has worn away at the drivers side mount making the hole not circular. Lever pulled up squint towards the driver seat, and only a couple of clicks. Wouldnt hold anything. Also discovered that the oval shaped bit that fits onto the tunnel was coming away and pulling upwards which did not help. Friend doing a weld, with me in the car with bucket of water and air hose at the ready in case of fire! Managed it without removing seats or carpets. And, no damage caused....
I now have a car that can sit on a hill - first time ever!
Took it back to the testing station. Guy had a quick ( real quick ) look at the weld, made sure the handbrake lever pulled and worked now, and handed over certificate.
Now - only need to:-
1. replace leaking clutch master cylinder
2. fit a new set of BMW plug leads - cheap ones dont last!
3. fit new exhaust manifold / heatsink gasket thingies.
Oh, Malc - you busy?
