FI query for the boffins
Aussiecsi
Perth, Western Australia
Guys, as part of the engine rebuild process on my '74 csi ,it has been discovered that at some point the original FI Pressure Sensor ( part 13631360678 ) has been replaced with a Bosch/Mercedes sensor ( part 0280100112 ) ...does anyone know if there are any "issues" with using /retaining the alternative Sensor ?. Hope you can assist
Cheers, Simon
Call Robert jr at fuel injection corp. in Livermore California.
He can describe the difference.
The map sensor that is in it now will work fine. The original had a coloured sticker that matched the sticker on the computer under the rear drivers side seat. Do you have issues with the f.i. ?
Many thanks .The car has not run for over 14 years so thought I would address any potential problems as part of the rebuild process .Handy to know that the Mercedes map sensor can be used as an alternative given they are considerably cheaper than the original .Cheers, Simon
An inherent problem with your question is what else may have been modified or tweaked on your particular setup. Consider that an improperly jetted carburetor may permit an engine to run at adequate baseline levels, but not necessarily optimum performance levels. Same may be true with mixing and matching fuel injection components.
You did not indicate whether the ECU is original to the E9 or some other Bosch DJet. Next, it is unclear whether the Pressure Sender currently in place hasn't been modified or "remapped" or "adapted" to work with your setup versus the setup it was originally intended to fit. There are several sites that discuss care and feeding of the DJet and common modifications. Via trial and error there are many components that may be interchanged on the csi. Lambda sensor and/or an engine dynamometer feedback would be helpful to determine if the system is operating at optimum levels. For all we know, your setup may be operating even better than designed, but hard to tell via long distance. Only you can determine if performance and fuel economy is acceptable.
Dear Mr Cat, thankyou for your considered opinion. Yes, the ecu is the original and I believe all other components are original too save for the Sensor. Will advise the outcome when she's back on the road .Cheers, Simon
