FI Trigger points - lubrication
Christopher
London
The D-Jet manual states that replacement trigger points need the deflection pieces lubricated before installation with Ft 1v4 - anyone know what kind of grease this is (or it's equivalent) ?
Don't know if it is an exact replacement, but i have used regular distributor cam grease (for the ignition points) with no problem. Reminds me I need to check the FI points...
I wouldn't use dielectric grease for the trigger points or the ignition points. I have read elsewhere that dielectric grease breaks down when exposed to arcing that might occur with contact points. I use a distributor cam lube that is a mix of silicone and petroleum grease made for this purpose.
