corsachili
I have finally driven my newly reassembled CSL. For those that might have lost the thread, this project began with me trying to determine what was causing a very annoying stumbling/hesitation problem that I could not fix. I ended up with the head off, learned that the head had been butchered, contemplated many different options and ended up installing a used stock D-Jet head. During this period I had the engine compartment painted and a few problems with the original paint fixed.
After many trials and tribulations I finally got the engine back in and have now taken the car on two short test drives.
It's too early to know for sure if the problem has been fixed. The car does run, but there are a couple disconcerting problems. The first is that from 1K to about 3K the engine feels rough, almost like it's not hitting on all cylinders. At 3K is cleans up and smooths out rather nicely, but then the pinging starts, as if the timing is way too far advanced. I don't know how sensitive the D-Jet engine is to not having an air filter, but I am currently do not have one installed as I have had a bear of a time finding one. I'm supposed to have one today, so hopefully that will be the fix (although I can't believe it will). I had the timing set at 7 degrees BTDC with the vacuum hose connected (as called for, and the setting I had with the previous head) and it pinged badly. I retarded it 2 degrees and it's still pinging. Is it possible that the stock head has too high compression and that it doesn't like the 91 octane fuel us Californicators get? Do you other CA based CSi owners have to use Octane boost to keep your cars from pinging?
We'll see if the airfilter makes any difference in the rough running or the pinging, but as I said, I can't believe it will. I'll check in later when I've got an airfilter.
