Fixed the clock today...
Honolulu
Honolulu Hawaii
Having seen threads about fixing clocks, including Hack's recent, I thought I'd have a go at the spare clock (from the spare cluster of course, doesn't everyone have one?) J/K, but I do have a spare cluster, and had taken the clock out of it a year or three ago. So I went to the mancave and found the clock, nicely wrapped in tissue paper and a baggie, from years ago.
A "bench test" with a battery and a pair of jumper wires did not result in the clock hands moving, so (drat) I actually had a project on hand. Since it has been raining here it was a good day to make a mess on the kitchen table and that's just what I did.
After gathering tools and parking the car's battery on a spare towel on the table, I opened the clock. I had already pried off the chrome, so there it was, held together by three little straight head screws and the solder point. Off they came... and I stared at the little gears and stuff through a magnifying glass for 15 minutes.
I noticed the hands moved with very little pressure so maybe they weren't fixed to the shaft very well... so I thought I'd hook up the battery and see if the problem was hands or the guts. To my surprise the little motor started, gears turned and VOILA the clock was working. I sounds like zzt.zzt.zzt.zzt and the gears go round and round. I left it hooked up for 15 minutes and sure enough the hands turned. There is a little potentiometer (?) with a screw on it, presumably for adjusting the speed. In my amazement that it worked, I didn't check how accurate it was, and buttoned it up and soldered the pin that holds the works into the "can" in which it sits.
Now to take out and the clock in the dash and put in the working unit... I have big hands and clock removal, I read, is a bit of trouble.
Why didn't it work at first (and for the last 10 years I've had it)? I have no idea. It didn't work when sitting on the garage floor wired directly to the battery either, only started to go when on the kitchen table... think I'll verify running before trying to take the other one out of the dash.
Pictures of the clock guts are available to anyone who will use the search function (my digicam battery was on the charger so no pics by me). The clock I repaired was the "later" style quartz clock, not the earlier mechanical version. We'll see what's in my 8/72 production car but I understand that either will fit.
When the gages come out for clock replacement maybe I'll fix the odometer. On a roll here...
You probably have the mechanical clock in the car, not the quartz.
The interesting puzzle is how the +/- is adjusted in production. If the clock lags 30 seconds a day it will take two days between adjustments and then one can overshoot the other way. I was tempted to use a microphone to convert the tick-tock into a signal I can feed to a scope or a frequency counter and adjust the potentiometer that way. I finally desisted when I saw that the mechanical clock varies from week to week depending on who knows what. It is a beautiful instrument whose accuracy is no better than asking yourself what time do you feel it is.
Arde, I've wondered the same thing, given late 60's technology, how they might hav done the trimming. In theory if you do what you suggest, you could adjust it a few ms or fractions, either way. They had oscilloscopes in the 60's, correct?
Nah, they mostly used kalleidoscopes in the 60's and measured time in seasons.
Only Paul Newman could afford a Rolex.
as long as they didn't use a proctoscope!
Seriously, why not start running the clocks way before assembling the car to dial them in?
Presumably they were just sitting around anyway. Not much "just in time" inventory management then....
That is brilliant insight Stan! If you plan to build 6.000 cars a year you start 12.000 clocks the year before and at assembly time you just pick one that still shows perfect time! The remaining clocks are randomly adjusted and combined with another 6.000 for the next year.
Darwin is working for you without being on the payroll.
Management is so happy they promote you, now you start 12.000 radios, 12.000 engines idling, 12.000 water pumps, 12.000 thermostats and so on. You become a manufacturing legend. Then Japan happens and you do not know what hit you. Oh, well you go to your cellar and open one of your 12.000 Chateauneufs and ponder...
