84E24
I was changing out the metal lines calipers and the brake hoses on the front brakes and one of the hex heads of the line that comes from the master cylinder round right off.
Now just short of replacing the entire line from the master cyl. to the passenager side is there a way I can cut the existing flare off, get a new seal/screw and re-flare the existing line.
Does anyone know what the flare is called ? Double or Bubble or what ever. It does not look like a standard type flare.
Also if you know of a tool to do this where can one be had ??
Thanks, Steve
Thanks, Steve
