Gratuitous advice
If I may, the rubber donut obviously expands when the band is removed. If the worst happens, i.e., you have to remove the guibo after having removed the band, there are a couple of easy fixes.
First, you can get yourself a large size hose clamp (the type that screws tight) and how you use it is fairly self evident. I have a couple guibos that have several clamps screwed together to keep the guibo compressed.
A second alternative is little less pretty. Use a big pair of Channellock pliers. You can start with one bolt and then proceed to squeeze the entire disk so that you can fit a bolt through the opposite bolt hole, then proceed to the next hole, etc. In a pinch, you can always use a prybar or screwdriver, but the band certainly makes things simpler. While this method seems lacking in finesse a guibo designed to handle the repeated shocks delivered from your engine to the driveline would likely be capable of being manhandled. To be sure, I am not advocating one abuse the guibo, but merely suggesting one need not necessarily handle them with kid gloves.
As an aside, there is an alternative guibo you might consider using along with shorter bolts. I am unfamiliar with the part number, but I believe it was used with the later automatics, the 530, the e24's and even the 02 automatics. This guibo is flat and reinforced with some sort of fabric, a la the belts commonly found in tires. The style guibo you are installing will likely cushion from driveline shock better, but when it fails - you get rubber chunks. The "reinforced" guibo wont chunk itself to death, and will outlast the solid rubber one many fold.
