Hey guys,
Do the Auto cars and the Manual transmission cars have the same floor pan?
My car used to be an Auto, but now manual.
The reason I ask is I am having trouble with getting my CR 5 speed up high enough in the tunnel to get the prop shaft to run straight from the gearbox to the diff, as it sits at the moment I have the gearbox as high as possible in the tunnel (just 5mm clearance at the closest point) I have had to lower the center hanger bearing 30mm to relieve any bending of the rubber donut joint as a result of pushing the hanger bearing up to its standard position in the tunnel.
A flow on effect of me lowering the center bearing now is a loud knocking from the bearing when a lot of power is applied (standing start hard acceleration etc) I'm guessing its being flapped around quite a bit on the rubber diaphragm within the outer shell of the bearing assembly when this happens?
This weekend we are going to try and get the gearbox up higher in the tunnel and get the drive shaft running straighter, I think we will have to "massage" the tunnel a little here and there with a hammer to get clearance in places.
I have mentioned this problem before in another post but got no feed back from anyone? It just seems strange that I'm the only one that's had this trouble??
Anyone else???
Steve
Anyone else???
Steve
