Floor plugs - To weld or not ?
westoz3.0csa
Perth, Western Australia
Having stripped all the bitumen layer from my floor to check out its condition and give it a coat of epoxy, I am pondering what to do with the floor plugs.:???:
I can't see that they serve any real purpose (other than be a potential entry point for water) and once covered with a new bitumen layer (Dynamat or similar) can't be accessed anyway. I note that any new floor sections are solid and only have the floor plug impression pressed into them.
I am considering welding them or maybe using some adhesive like JB weld or similar or making up a rubber seal and screwing them in.
So ... what have you guys done with yours? ... if anything.:grin:
thank you for your input
Carl
The lore is that these holes were used to drain out excess primer/sealant when the bodies were dipped at the factory. Whether this is true, I cannot say.
So you're right - unless you plan on dipping your bodyshell in paint, the holes don't have any useful function. Most people welding in new floors just use solid sections.
Carl,
I just welded in some round sheet metal flush with the opening. Clean and simple. I suppose if you were going to dip the car then the hole would be needed for drainage (then weld them shut later).
Carl,
That's what I did too.
Body panel adhesive. Waterproof and no welding or grinding. 4000psi; you'll tear the metal first.
Or if you're feeling lucky- liquid nail. 400 psi.:shock:
I would remove them, clean everything up epoxy the floor and plug and just reinstall them with urothane seam sealer then spray over them with a product like 3M body schutz. Then paint the floor before the tar boards go back down.
