volecewest, im pretty sure that's what i did. the manual instructs you to put the engine at TDC, turn the rotor 1.4" counterclockwise from the notch in the distributor body (being the one that you mentioned you were not sure was there or not, where the #1 contact is, then insert the distributor, which will turn the shaft to where the contact on the rotor lines up with the notch. fortunately, the wires were allready connected and the lines have become so hard that you can't arrange them any way but the correct way (ha!) but the harness will be replaced soon, thanks for letting me know what the numbers above the zundfolge mean, i wasn't aware
