Front Control Arm Torque Settings
PhilipTheBavarian
New Member
I need torque wrench settings for the front control arms from a 72 e9/e3
Control arm to crossmember - (120-130?)
Tension strut to control arm and crossmember - (50-65?)
Sway bar end links - (?)
THANKS!
I just used the same force as it took to remove them, they use cotter pins or self locking nuts anyway. Use a half inch drive ratchet and socket. Sway bar nuts don't need as much force, you have two nuts, just make them real snug.
