nashvillecat
- Messages
- 115
- Reaction score
- 7
Within the past 18 months I replaced my lower control arms, tie rods including center link and associated rubber. Car seemed fairly tight and roadworthy. I had new sway bar bushings which I did not replace pending my location of a bigger sway bar that I used on another e9. This past weekend I stumbled across the swaybar which appears to be 25mm or 1" thick. The swaybar I replaced was considerably thinner at anywhere between 19 to 22 mm in diameter. I decided to reuse the old mounts given the size differential and because I noticed the newer mounts were all urethane.
The strangest thing is that the car definitely takes turns with less sway or flatter. However, the steering seems less responsive or sluggish in that the steering wheel does not seem to center itself with as much speed as before the larger bar installation.
My question is whether any of you have encountered this phenomena. Is it that the end links are too tight or the mounts themselves too tight? I do not hear any unusual sounds. I may disconnect the bar and try driving it to see the effects, but that is the only recent suspension modification. I might add that I wanted to adjust the steering box, but out of frustration (especially due to inclement weather) I abandoned the project.
Thank you.
Thank you.
