Bwana
I'm replacing the factory springs and shocks with the standard setup from LaJolla. In removing the strut, the top comes off fine but the bottom of the strut seems like it's welded on. I've removed the three safety wired nuts/studs but no movement. I'v heard from another Forum member that I may have to remove it all via the lower ball joint but I'm trying to avoid that. Any suggestions on how to split the strut from the fiting that sits on the ball joint?
You can see where the three bolts came out and where I'm attempting to split the strut from the ball joint fitting. Maybe I need a bigger hammer?:mrgreen:
