FS Getrag 5 speed O/D trans
Bert Poliakoff
Scottsdale, AZ
FS Getrag 5 speed O/D trans SOLD
This is the hard to find desireable 5 speed over drive gear box,with the removable bell housing that has the ports for Motronic sensors.The gear box itself has provision for a mechanical speedometer drive, which is there along with the gear drive and sleeve. The case shows 262.05 which was the front case from the four speeds. it has the third section, which is what was used by Getrag to manufacture the transmissions we know as the 265/5, which is the strongest gear box built for the M30 engines. The bell housings themselves are getting very hard to find.
$525 . Shipping and handling in the lower 48 should be about $128 UPS, or I can put on a Greyhound for economical shipping
SOLD
yes shipping will be expensive. $825-$850, with the limited info that you have provided me. I obtained an estimate by using a general postal code for Bilbao
where is the trans located?
if it in CA i can drive through and pick it up maybe, and save shipping cost.
i am in OR and go to SCal a couple of times a year
I am in AZ. Shipping to you will not be too bad by Greyhound. The gas to come here from Socal will cost as much as the shipping which, by bus will be $75-$100
