MM'22/2
Professionally restored aluminum "early"-style kidney for e9 or e3.
Please see photos for condition.
Notes: Original glue and anodizing removed. Parts polished, ceramic coated and reassembled. Slats taped with aluminum tape to re-secure. Original posts/studs remain. You may need to remove broken mounting studs with dremel tool and drill out to add screws/nuts. Or use intact posts in combination with zip ties. Post pictured is probably the best one of the lot.
"Facelift" plastic 4-slat kidneys are available new from Walloth & Nesch and others if that's what you need. If you're looking for a reasonably fresh, original 5 slat model send a private message.
Price at $550 - including shipping & is about what you'd pay for a new plastic model. Not cheap, but no part of the restoration process is. Local pick up option in S.F. South Bay. Cheers.
