FS Rough to driver quality interior parts
eriknetherlands
Netherlands, Eindhoven area
One e9 fuse box door, rusted hinge, nice twist lock button, vinyl face without tears, dents in top right upper vinyl corner, rusty carrier, bent wire thingy for max opening position. No separation of the vinyl from the steel carrier! (yet...)
Flocking on inside needs cleaning, and regulating to the steel carrier. Fuse box label is missing, but repro's of these are available.
50 euro. Located NL, will ship worldwide, PayPal preferred.
One e9 under steering column cover. vinyl face has some tears and is separating from the carrier, bottom is even taped up. Rusty carrier.
Has all 5 brackets.
I'm not sure what the electrical connector is that is mounted to it.
I'd say only suited for those on a tight budget who are missing the part completely.
20 euro. Located NL, will ship worldwide, PayPal preferred.
E9 glove box 60 euro.
Ideal candidate for restoration as the vinyl is without tears, apart from one 15 mm tear, of which 10 mm is on the side facing the passenger.
Vinyl is separating, comes with the large overhanging hinge , and small hinge mounted to the firewall (which has rust)
Prices are just a guess from my side, let me know if I'm off. Zero intention to get more then market value.
Btw, these part match in shape exactly what I have in my 1973 3.0 CS, not sure if the will fit other years (I believe that perhaps the under steering column cover has variants for telescopic system. My part does not fit with a telescopic system)
I might be interested. I would need to check condition of my parts. As being in EU should be fairly cheap to ship. :)
