Have a number of parts I am clearing out. All prices are plus shipping. Have price now for some and will be adding more prices shortly
- Air Cleaner - $125
- NOS Wheel Center Caps - $300
- License plate center panel, needs work - $30
- Side grills, need work - $30
- New Front Caliper (2800/E3 Only) - $50
- Used front and rear rotors, can be turned (3.0cs/csi) - $75
- NOS accelerator pedal (older style) - $100
- NOS front and rear caliper rebuild kits - $75
- New W&N full rear axle hardware kit - $85
- Dash top, fair condition
- Dash gauge cluster surround, some minor cracks
- Upper dash aluminum trim, good shape w/very minor surface scratches - $200
- New, mostly OEM five speed parts (See picture with part numbers
- OEM bushings, pins, retainers (See picture)
- seals (See picture
- OEM Gear selector rod - note this is the type that needs the deeper transmission side connector, not like the connector listed here.
- OEM fork
- W&N clutch pressure plate bolts
- Clutch Master cylinder
- Would like to sell this together if possible, exception being the mismatched shift rod and connector
- Used OEM fork
- New front control arm bushings x4 - $75
- Pile of sway bar bushings - free with something else
- Used front tension strut - $100
- New W&N batter terminal - $35
- Original side mirror, missing mirror retainer, fair condition - $40
- NOS wheel shaft seals
- OEM hella horn
- 14x6 +22 OEM wheel - $150
- Original steering wheel - $300
- NOS interior sound insulation, various pieces. All are soft and the foam is in great shape. Only the large one needs a tiny bit of work with spray adhesive between the rubber and foam
