Assuming your ECU is under the right rear seat (and your coupe is otherwise wired the same as mine), there should be a relay next to it which operates the fuel pump. Check that. The ECU relay, also called the main relay, is under the hood (under the MAP on the brake booster extension and is next to the Cold Start relay.) The fuel pump and main relays each have 5 wires, but one could adapt the more usual 4 wire relays to work if replacements are hard to find. In my experience rapid clicking from the starter solenoid is a sign of a weak/bad battery; I've never heard other relays click rapidly with a battery issue, but who knows? HTH. https://e9coupe.com/forum/threads/car-not-starting-rapid-clicking-etc.38704/#post-332295
