Thanks , I will check the voltage, I pulled apart and cleaned the relays, I then had the lower points in the dizzy checked and found that the shaft was bent , probably when the lower gear was replaced , which gave dramatic difference in the pulse rate from side to side,I hopefully have a line another dizzy. Thanks again for the help, probably not the right forum for this conversation , I will respond next in E9 forum.
I'd say just get a 123 dist but since you have a CSL, it's harder to make that call. Everyone says the trigger points sets are incredibly hard to find. I'd love to find a spare set as well but as everyone says... Hens teeth
