Fuel injector line and hoses
Neil3478
New Forest, England
I have asked before but still cannot get this right, if anyone can help!
Top of the engine on my 3.0Csi are the 2 long U shaped fuel lines. In the middle is the injector pressure regulator. Each of the fuel lines have 3 short pipes that go into the fuel injectors.
What I am trying to get is a picture or photograph of how the whole thing is connected, ie which rubber hose goes to the pressure regulator, what connects the front of the pressure regulator - it has 3 outlets and not sure what connects what!! Where the fuel line goes in and which pipe connects to the downward pointing plastic connector on the top of the engine. Does anyone have a diagram, photo or picture.
I have removed the 6 aluminium curved exhaust pipes of the engine so easy to see what I am doing but just cannot work out how the hoses are connected, especially to the pressure regulator. It should be so easy!!
It seems like that the 2 outward pointing pieces of the pressure regulator have hoses which double back on themselves to go into the fuel lines and the front bit goes up to the plastic connector?? Any ideas
Many many thanks if anyone can help!!
Car is a 3.0 Csi, UK, manual, RHD. Thanks
These cars share a lot in common with the E12, perhaps finding an E12 image may be easier
Does this help?
I cut the hoses to get in my suitcase
I took a few of a CSi fuel rail that was all together if it helps any further. Don. I tried sending you some PMs. Not sure if you get those, but if you have an answer to my 1.3 wiring questions, I sure could use your help. I take it that 730i manifold was already gone. Sorry, I missed that post....
