BarnE9
Have read several posts relating to fitting a non return valve to solve the 'hard to start after standing idle for a while' issue. Thinking of fitting one to my 73 Csa (Zenith's and pierburg manual fuel pump) but would appreciate advice on best location. Have read it might be advantageous to fit close to fuel sender in boot (trunk) rather than in engine bay but is this mainly for aesthetics or does the additional distance from the pump actually help with cold start? If the engine bay is fine is there a minimum distance from the pump you guys would recommend?
