Fuel Pump Relay
EggUK
Essex, UK
When I purchased my CSI I was aware there was an issue with the fuel pump relay, for the purposes of demonstrating the engine running, the pump was wired permenantely.
Would I be correct in saying the location of the fuel pump relay is under the rear seat along with the ECU ?
Could anyone possibly provide a photo of the location ?
Many thanks in advance.
Yes, fuel pump relay is under the rear seat near the ECU, it's the small metal box attached to the upper back of the seat riser.
When is the fuel pump supposed to run?
Can some one explain when the fuel pump should run and not run on a CSI. My one seems to run all the time, clearly the engine needs fuel all the time it is working, but in the event of an incident I would like to think that it cuts off. There is a flow and return pipe, so I assumed that it ran constantly and the pressure regulatior just returned what was not used.
C
Good question Charles - mine too runs all the time. I have heard of the safety cut which may have been a feature on earlier models. Would be interesting to know for sure
turning the key on provides battery power to the coil and to the main relay.with the main relay on the fuel relay now has battery power which is fed to the fuel pump and into the cold start relay.it is the ECU that provides a ground and a positive for the signal to the fuel pump relay so that the fuel pump and the cold start relay get power.
Check pins 19&24 for 12 volts at the ecu.
They correspond to 85&86 at the relay
  • Like
Reactions: LEO
FI relay
When I flip the switch, there is about 1-2 seconds of a 'hissing' sound....then the engine fires up and I could only assume the relay is 'off' or the system is using other means to regulate itself...
Hope that helps,
MF
Having not been under the seat In a long time are the relays replaceable with a newer relay? They are over 40 years old.
Yes they are replaceable with a new relay.
Bosch 0332 019 150
It is the same relay as the main relay, except one of the spades is turned 90° on the main relay. We took the good fuel pump relay, turned the spade and replaced a toasted looking main. Used the pictured Bosch for the hidden fuel pump relay. Has been working fine for 3 years.
Bosch 0332 019 150
May need one of does myself.
Lots of these on ebay. As Steve says, carry a spare.
