Gauges for sale
Ed G
Eastern Connecticut
I'd like to send these off to one buyer. All gauges are 60cm, are lit electrically, and are Series 1 VDOs. $140 gets them all to you.
1. Oil gauge is 0-100psi with 1/8-27NPT electric sender.
2. Coolant temperature is 100-250 ^F degrees with a 3/8-18NPT electric sender.
3. Electrical gauge is 8-16 Volts and takes incoming voltage from line.
Yes, I still need to add a switch in the glove box so it's not on all the time and prevents me from obsessing over the afr's. I also wired a power jack in it for the radar detector. The actual cutout size of the gauges is 2 1/16" = 52mm, I think 60mm is the OD of the bezel.
Did you wire an AFR display into the fasten seat belt screen?
Brilliant!
