Malc
The bakes appear to be soft (like they are extremely over servod) but work great, after a while the pedal gets firmer and firmer (brakes still work very well) untill they start to bind. After a while (could be 10 secs upto 5 mins) they release themselves and become soft again. I'm begining to think that I may have two different problems which is confusing matters somewhat.
It could be that I have made the link rod between the pedal and the transverse link too long, this could be why they start to bind after the (possibly faulty???) accumulator has managed to build up pressure.
I spoke to a guy who was a BMW teccie when this system was current and he said that the system never really gave any problems except for the accumulators so thats my best guess at the moment. I'll have to bite the bullet and order a new accumulator, its a big pill if it's still the same afterwards though.
Gazzol,
Things that may help, make you think or can dismiss straight away!
Have you any adjustment in the linkage? It is possible that when you take your foot off the pedal the servo and hence the master cylinder is not returning to the "rest position"
I was told a failing accumulator results in a wooden pedal and the assistance becomes dependent on engine speed thus the speed of the PS pump.
Run the car then switch off the engine and pump the brake pedal. If the accumulator is "good" you should get the feeling of assist for a few pumps as it were. If this feeling dissappears after only one or two pumps then I would suspect the accumulator.
Are you using the original PS pump or did you fit one from the car that had the accumulator? Don't quote me on this but the output pressure from you current pump maybe too low?
Have you changed the brake flex hoses? the standard "rubber" ones can swell internally over time and act like a check come bleed valve
Accumulators are available secondhand/reconditioned and new from none BMW sources at reasonable prices, such as GSF (German Swedish and French) and the usual culprits such as Munich Legends and your local scrappy!
Malc
