Gearbox
CHRIS
Ireland, Waterford
Hi everyone!
I bought a 1974 RHD 3.0 CSA and I would like to change the gearbox to a manual gearbox.
What type should I use?
I think the 4 speed. But I wonder could i use a gearbox from E3 or any BMW models? Will she lose from the value if the gearbox is changed?
It won't really hurt the value because the stock auto box is rubbish. Many on here have converted to the stock 4 speed or a later 5 speed. Most switch to the later 5 speed because it either adds another intermediate gear (if you use the close-ratio dogleg box) or gives an overdrive gear for highway use is you use the OD box. Most use the OD box, as it is significantly stronger than the dogleg CR box.
There are many, many threads asking similar questions to yours, as a manual/5 speed swap is arguably one of the most common questions asked on this forum. Take a search around and you will likely find exactly what you want to know.
