Getrag 265 Transmission & M30b34 Engine
BmwCalvin
Los Angeles, CA
I know these may not be normal parts for the E9 guys but figured I would offer them up here in case anyone is looking.
Pulled the transmission and motor out of 1985 735i-
Getrag 265 transmission- 262.0051090- Comes with the bell housing to mount to an M30. Could be good for a 5 speed swap if you would like to add a mechanical speedo gear.
Asking $1300
M30b34- Starter was bad so I couldn't get it started (just kept spinning super fast so it wasn't making contact with flywheel) but the engine spins by hand and the inside of the head looks clean. Also the oil was clean when I drained it. I noticed the oil pan has been welded to repair it. Could be a good parts engine or ?? Asking $450 Comes with the wiring. I also have an ECU for it as well. Block says 3.5 on it.
I'm located in El Segundo, CA but I can deliver locally no problem!
