Glue for hood insulation
I will do that job tomorrow with stock isolation (80$ from dealer).
Even though foam is peel and stick, I also will use contact adhesives on the hood.
If you feel you need additional adhesive, try to find Wurth contact cement. It's great for rubber trim, can be removed without damaging the paint and is easy to use. Recommended. Do not use 3M weatherstrip adhesive in any color: It will pull off the paint if you ever want to remove the seals.
