GM style hydroboost swap
aguirola
El Salvador
What is the procedure for fitting a GM style hydroboost in a CS with DCOE's?
Thank you.
Regards, Alberto
I did it 2 years ago.
Had to modify the mount on the firewall. Shorten.
Also the angle of the brake pedal rod and the new booster has to be adjusted.
I have great brakes but the pedal pressure is a little higher than normal.
There is a company called Hydratech braking that helped me with mine. Other companies as well but they were very helpful.
Basically the master is from a Chevrolet.
It runs off my power steering pump but they make an electric one as well.
