Hi I have been enjoying the company of two sets of zenith inat carbs during last holidays
I have been using new spare set of gaskets, washers, membranes, rings, and so on
but there are three seals that are not available or they might be not appropriate quality (at least the material used is unknown)
these are:
1- the small o-ring that seals the conection of the two sides of the volume that encloses the round membrane, see here:
this seal is usually flat due to heat cycles and ageing, so if you do not have a way to replace it and if you use the same one, most likely you wont have a perfect seal and your max acceleration will not reach the value it should
this is a fresh new seal, it protrudes from the surface thus it will seal perfectly
2- the cutoff valve seal that goes in the small cup
i have never seen spares for this one, same as others it suffers heat cycles and deteriorates losing its function, usually cracks and dissapears
i can not find spares for this, but i have successfully replaced it with a pile of 3 o-rings
3- the o-ring seal the seals the iddle screw in US type carbs,
if this seal is worn, the iddle screw will rotate and you will lose the tuning and air will come in through it
these are:
