hello
Infos concerning front dash can be found in the posted thread.
Removing of the front windshield is mandatory, or highly recommended.
Concerning the door wood panels, after removing door handles and stuff from the inside panels, pull them away.
Then you will find, screws (photo) tightening them to the frame.
When all removed, lift the part from the upper door frame.
Then on the other side, you will find a cloth glued to the metal.
Under it (photo) you will have screws holding the wood.
unscrew (4 for rear, 5 or 6 for front)
and this is it !!!
...if this can help !!!.
