Had to change the gearbox input housing
Ed G
Eastern Connecticut
On my 5 265 speed. Can anyone advise what speed the shifter needs to be in, to reassemble back together (along with tuning forks)?
Thanks,
Ed G
5th gear so you can turn the output flange to facilitate mating with the pilot bearing/input shaft
Can't clamp down the final 1/4" of play with the final housing. I have a feeling that the rod end pivot points are blocked off in the support housing with the adjusting screw mechanism. All else seems to be ok.
Any ideas?
