taylorcom
Hi all,
I've posted on this in the past, but want to add new info. The issue is that in hot weather after lots of stop-and-go traffic, my 1972 BMW 3.0CS gets hard to brake. The brakes work fine, they just take a lot more leg-power.
My guess is the brake booster has stopped working in these conditions (always warm weather, and lots of stop-and-go driving).
In cool weather, however, the brakes work great, very sensitive to the slightest toe-tap on the pedal.
Here's what I've done to the braking system in recent years:
-- replaced both front calipers and brake lines, using rebuilt calipers.
-- replaced one of the rear calipers w/ a new one (not sure if line was replaced).
-- checked the vacuum line to the booster, and the one-way valve, and they both seem intact and clear.
So the car has fairly recent front calipers and lines, one very old rear caliper, and probably 2 very old rear brake lines.
My question is: could an old rear caliper and old rear brake lines cause the hard braking in hot weather?
Or is the culprit more likely the brake booster?
If it's the booster, where can I get a replacement?
Thanks,
Steve
Thanks,
Steve
