Re: Head bolt controversy
Snip.......
To me, a bigger controversy exists whether to coat the gasket with copper spray or leave it naked and clean. (Do not need to be reminded of junction with timing cover.) I have also heard differences of opinion regarding the coating of head bolts with: nothing, motor oil, anti seize, and yes - even some sort of adhesive. I typically go dry, but have dunked bolts in oil with other marques.
HTH
bengal taiga,
I guess we all have our "own" ways of doing things, plus all makes of engines too!
I have rebuilt engines from MG, BMC A series, mini etc, Land Rover, Citroen, Fiat, Lancia, BMW :lol:, Yugo, Jag etc. All seem to say different things about it but my "rule of thumb" is as follows..... Please note this is my way of doing things and is no more valid than other folk's way of doing things!
1)... Everything clean and dry!
2)... clean out threaded holes in the block, ensure a bolt goes to the bottom, If "raggy" run a tap down them
3)... Most modern gaskets appear to be coated with a sealing agent and often have deformable "goo" around the cooling and oil passages. Check instructions about using sealants etc!
4)... Check the bolts and replace if any suspect.
5)...
Very lightly oil the threads of thead bolts, using a light machine oil
6)...
Very lightly oil the washer or underside of the head bolt.
7)...Follow instructions about tightening
8]... Be smooth and progressive when tightening, no jerks or "just a little more" type snatching!
9)... Get the job done in one go, IE make sure you have everything ready.
10).. Make sure you have a decent torque wrench! You can even get them calibrated for a few quid to check that 50ft-lbs is really 50ft-lbs!!!
I learnt this stuff from my Dad and his life long pal Mr Manors, who used to fix aircraft engines during the 2nd world war. An amazing chap with some really scary stories who though now long gone still influences what I do!
Malc
