Headlight plastic grille surround repair
E9Wayne
okay, with the center grille project successfully done from last weekend (with appologies to Steve Armstrong for not executing this as well as he did) I noticed the passenger side headlight grille surround had a broken mount. So I removed it and inspected it this morning and noticed several of the mounting points had the plastic broken or cracked. With Gorilla Glue and some small washers in hand, I reinforced each of the mounting points, including the big one in the corner that was missing most of the plastic trim around 50% of the screw hole. I hope this keeps thing secure a little longer.
Should we not commission a new batch of these grille surrounds to be made? I noticed a single side grille on ebay for close to $400!
Wayne
Hi Wayne - good to see you are tackling your spring projects. If I remember correctly, Gary (M5bb) has been trying to get BMW to reproduce these for more than two years.
i think Gary has had one on order for over 4 years. in talking with Gary on Sunday he mentioned that BMW had promised to have some in May. neither he, nor I are holding our breath.
