Just trying to reinstall the heater box and AC blower assembly and getting frustrated. I thought the sequence was:
1. Install heater box unit (this part was easy).
2. Attach the AC base plate to the top of the transmission tunnel (4 screws).
3. Slide in AC box, while guiding the two pipes through the firewall, and getting the plastic plenum to engage the heater box.
The problem is getting the plastic air plenum (which I have first mounted on the top of the AC box) to slide into the receiving end of the heater opening. The alignment is off by about 5-10mm. I am fairly sure that preassembling the whole thing and sliding into place will not work (no way to attach the base plate to the tunnel in that scenario + no room to tilt the heater unit fore/aft).
Any suggestions?
Thanks,
Any suggestions?
Thanks,
