hello
I would appreciate some help on this problem
atecedents:
1- I had no leaks in the past in this area,
2- I changed oil using 80w90 in november 2009
3- some time after that (aprox february) i started seen one or two small drops in the floor at that rear area of the car
4- little by little two drops increased to 4, 8 ,....,
5- I have no leaks in the rest of the car
a fact: when the car is not moving from the garage, no drops appear, only after a ride some drops in the floor appear, and after that, it stops
the issue:
1- last tuesday I cleaned the differential case, and checked the oil level (it was ok), I found a lot of dust mixed with oil, and dirty in the case and the sorrounding elements, and I cleaned almost everything with a cloth wet on gasoline
2- on friday it was hot weather and I drove the car 200 km,
3- when on saturday I checked the floor, I found this:
this is the size of the spill in a protection paper that I put under the car
the red arrow represents the point from which the oil drops fall into the protection paper in the floor, that part is a structural member, the transmission tree that passes through the mentioned structural member is dry (no oil on it)
all the blue area has no leaks or drops falling from it, neither the blue arrowed conection points to transmission tree and to the wheels
the strange thing is that the dropping point is situated frontwards relative to the differential, in a structural member of the rear suspension, and in the way of the transmission tree I can not appreciate any oil or leaking (i.e. the possibility of the leaking differential conducting the oil frontwards through the mentioned transmission tree), the rear braking deposit is dry, and the brake fluid level is ok
can anyone help ?
additional information: on saturday I cleaned that area again with a dry cloth, I drove the car 20km, return home and put the protection paper to check any spill. the result was: no drop on it, nothing
regards
atecedents:
the issue:
![10sbtiw.jpg](/forum/proxy.php?image=http%3A%2F%2Fi49.tinypic.com%2F10sbtiw.jpg&hash=2c9e17eaf795dda638b1b5f644e2a724)
![2j4udqv.jpg](/forum/proxy.php?image=http%3A%2F%2Fi45.tinypic.com%2F2j4udqv.jpg&hash=ac17a081f204c08a91b6408fb0bfaf63)
![20upp3n.jpg](/forum/proxy.php?image=http%3A%2F%2Fi50.tinypic.com%2F20upp3n.jpg&hash=98e5c5af1e815edb605543fc9431a7e1)
can anyone help ?
regards
