hi,
I would appreciate some help with front bumper dissassembly and repair
I am trying to renew the front right bumper section, and clean and renew bolts and nuts of the rest
I noticed one lateral screw (ref.5) in each right and left parts, and then the central part has two long metal plates (Ref. 8 ) that come inside the engine compartment and are screwed to the front chassis members with two nuts each (ref. 11)
I have tried to dissassemble the two mentioned metal plates, but when i unscrew the nuts, the bolts (ref.12) are there and it is not possible to remove the metal plates unless you push the bolts to inside the chassis members
but, as the bolts are not passing the chassis members from one side to the other I am scared about missing the bolts inside the mentioned chassis members
any idea ?
regards
any idea ?
regards
