couttsdesign
I can't get the speedometer drive gear off the output shaft of my original 4 speed transmission. Supposedly, it should just slide right off, as it is just press fit on the tranny output shaft. I've tried various lubricants, heat, a slide hammer...it won't budge. Any tips or tools that anyone can recommend? BTW, I need the gear for a 5 speed swap I'm currently working on.
Also, what's the best way to remove the rear crank oil seal? The seal looks tight and I don't want to damage anything while trying to remove it.
Any other tips or words of wisdom for this Getrag 265 5 speed swap would be greatly appreciated!
thanks-
thanks-
