Can anyone help identify this relay, located in the top corner to the left the fuse box?
Many thanks
Sid
Sent from my iPad using Tapatalk
Many thanks
Sid
I think that's the "load shedding" relay. It's kind of important; pretty much all the car's electrical devices are switched through it, taking the load off the ignition switch contacts. It also shuts off power-consuming devices while the starter is running.
yesI think that's the "load shedding" relay. It's kind of important; pretty much all the car's electrical devices are switched through it, taking the load off the ignition switch contacts. It also shuts off power-consuming devices while the starter is running.
