Help - stuck bellhousing
I've removed 8 bolts from the bellhousing - are there any more? It doesn't want to budge - any advice - I don't want to f@$% it up now. Do I pry it or hit it or what?
5 hours to get to this point from raising it on stands to these nuts. Tranny out.
Thanks.
Just stuck.
Large scewdriver as a wedge.
2 x 4 and and hammer.
Spray your penetrant dejour.
Jack and a piece of wood.
It'll come loose. Probably first time ever in your case.:-D
I will watch the liquid wrench work as I have my coctail(s).
Phase 2 bellhousing, clutch, flywheel, and pilot bearing removal tomorrow. Then flywheel to machine shop.
Phase 1 complete - tranny shifter seal replaced (I botched it the first time).
It's too swelteringly hot here to drive it so I figured I'd do some maintenance.
Which tranny is this?
Did you remove the slave?
Gently pry at the bottom with a big screwdriver at the flywheel- watch for a stuck side to show a bolt still in.
2 13mm bolts at top
2 17mm bolts top left
1 17mm left middle for hose bracket
1 17 mm bottom left
1 17 mm bottom right
1 13 mm mid right
Getrag 4 speed.
If I pry at the bottom with my wrecking bar it only seems to bend the thin metal plate behind it. Also difficult to get a hammer or other object on it to hit from the front but will try the pry technique again tonorrow.
Slave is off. As are 8 bolts but will check your list with those lying under the engine. Don't recall that many 17mm bolts. Thanks for your help.
2 13mm bolts at top
1 17 mm bottom left
1 13 mm mid right
Chris is right - 3 10mm bolts have to come off. 1 bolt is longer and holds it all together. Plate comes off
Got it - I had only taken the one long one off thinking the other 2 (they are 13mm) weren't holdng it on, and I missed a 17mm hidden up top. Thanks guys - onward to clutch, pilot bearing, and flywheel removal.
