help with the electrical connection of the VDO clocks
deQuincey
Quousque tandem...?
hi
i am trying to install 4 clocks to have a fresh information of key parameters from the engine behaviour (volt. oil temp, oil press, water temp)
so i bought VDO gauges and instruments and i am trying to install the hardware part, and the electrical conection too
all the sensors are always connected to minus-ground by their installation thread, and then there is a free conection faston spade that goes to the clock instrument
the clocks came with a 8 pin connector and two possibilities of connection ways:
- warning contact minus ???
- warning contact plus ???
1st question: how can i decide one of these two choices ? and why ?
2nd question: pin n.5 says: sensor, so, ok that will be a cable from the spade faston in the sensor, right?
but then comes pin n.3 saying sensor minus, and what can i do ?, i do not have any other spade in the sensor, so what am i supposed to connect there ???
by the way, the identification of the pins for the case "warning contact minus" are :
pin n.1 plus connected ignition
pin n.2 ground (minus)
pin n.3 sensor minus ???
pin n.4 free
pin n.5 sensor
pin n.6 lighting (may i assume this is a plus (positive) ???)
pin n.7 warning led (ground) minus
pin n.8 plus connected ignition
please help !
last question: the voltmeter should be connected to a positive to meassure the power of the electric installation, but where to pinch ? in the positive pole of the battery, or in other positive point ?:
i.e. alternator ?, rectificator ? regulator ?
thanks for your patience
regards
VDO Guage help
Try this website; http://www.egauges.com/Inst_PDF.asp#InstrumentKits
They have wiring diagrams for each guage. ( You refer to clock)
I can't tell from your earlier post which guages of which specific type you intend to install. So if you can clarify that by guage, face( reading), and sender it would help a bit.
Each guage should have a light or lights. The grounds are usually just for that; but again it depends on the type of guage and sender. So, if you seperate the function from the lighting, it gets a little easier.
Tip- there are electrical "taps" that both clamp and tap for the new connection; what I mean by that is that you don't have to cut and splice, keeping the original wiring in tact.( some even with fuses!)
thanks jerry
yes those drawings for old vdo gauges were interesting, i can follow the explanations,... but nothing to do with the new 8-pin system, they were much simpler
now the 8-pin system permits more complex connections and that is my problem, when a lot of choices are in front of you, it is difficult to get the simple solution
anyway thanks for the link and i try to check it again, and clarify my ideas
regards
