Help?
Koopman
Uxbridge,Ma
Hi;
Does anyone know if 1500 - 2000CS 14" hub caps will fit 2002 14" 4 lug steel wheels?
Koopman
14"?
I'm not aware that BMW ever offered 14 inch steel wheels for the 2002. I have a 1965 Neue Klasse 1800 that came with 14" four lug steel wheels. I have the NK hubcaps and they don't work on E30 14" steel wheels. I tried that. Perhaps the 14" steel wheels you have are something other than BMW, like Alpina. Wouldn't that be awesome?
all 2002 came with 13" wheels - even the turbo. the standard steel wheel was 5.5 x 13 w/ et 18 or 20 ... if i remember correctly there were 2 versions of an aluminum wheel - the first looked similar to our coupe wheels 5 x 13 wheel w/ et 28, and a 6 x 13 w/ et 13 that looked different.
Wheels.
Thanks guys for the info.
What I have is a brand new set of full 14" hub-caps that I need wheels for. According to Real OEM the hub-caps are for all 1500 thru 2000cs. I thought that it may be easier to find 2002 wheels not thinking that they were all 13". I should of known that since I owned three 2002s in the past. Now I have to find wheels for those hub-caps.
Thanks again.
Koopman
