As the title says, I am new, but kind of (had some admin difficulties at the beginning but all good now). So I figured it's time to say hello and jump right in...
I bought my friend Scott's (aka "sreams") blue '72 3.0CS last summer. Since then, I have been navigating my way through ownership - both the work/technical and the fun stuff. I have learned a lot from this site, you guys are awesome and seem like super nice people, so I truly appreciate the existence of this forum.
I'm really digging this car, and of course it has become an obsession. Scott did a great job doing the B35/Getrag 265 swap and suspension set up during his ownership. However, I have vision for the car - basically to keep it in the spirit of the E9, but continue to improve the performance. I am taking advantage of the fact that the car is solid, but the body and paint are not pristine (temporary paint job, minor dings and dents, etc.), and therefore I can really drive it and have fun, without the worries of paint/body damage. I feel this is also in the spirit and appeal of most other BMWs too, they are on the stock-to-modified spectrum and everything in between.
Here is a summary so far:
Since taking ownership of the car last summer, I have done a few repairs and upgrades. The highlights of what I have done so far include the very first task of replacing the broken timing chain tensioner rail, and therefore changing the tensioner, chain, cam sprocket, etc. It was daunting but I got it done, with the help of this site. In Nov. I bought the used triple Weber set-up from member "gdub0717" last Nov. Before swapping out Scott's dual Weber 32/36 carbs for the triple DCOE40 Webers, I installed a 123 Ignition distributor. Prior to the triple carb install, I took the car to a track day at Laguna Seca to get kind of a baseline feel with Scott's dual weber set up. It was fun despite having bad tires and pretty much drifting around every other corner. Pushing the car also aggravated a few subtle issues I was already having (I know I probably should have been more conservative about this and changed them first, lessons learn). However, I was able to drive home just fine with a cracked giubo (flex disc) and a bad center support bearing. In the process of changing those out, I went ahead and upgraded the rear trans mount to the SS one from CoupeKing.
Currently, I am in the middle of trying to tune the Webers - I'm getting close. It's running pretty good and my AFR numbers are OK, but can be improved. I have some additional jets from another set of carbs that I am going to experiment with, and also a set of the proper tiny drill bits if it comes down to that. Just want to say that I have gotten a lot of very useful triple Weber and 123ignition info from Stevehose posts, among others.
I have another track day at the end of June at Thunderhill, so I have a deadline. When I feel I am at the point of diminishing returns (if anyone is interested) I can post my Weber set-up specs, timing, etc. and maybe a pic or two. I am not any kind of real mechanic, but I know enough of the fundamentals to learn and figure out some stuff on my own, and with the help of the previously published info on this site.
I am here in Sacramento, so I am looking forward to meeting some of you in person and seeing your cars in the flesh. (Sorry for this long intro).
Thank you! -Larry
Thank you! -Larry
