steve
More specifially. Who would this group say has the most experience in building m30 engines. And could answer some specific questions about different configurations and the results they have. Like flywheel weight, intake size and cam charateristics.
I have had a couple of issues while doing some tuning work on the
engine. And this is a very non standard setup using throttle bodies and a integrated ignition and ecu. I need some answers to what can cause some of the symptons I'm having and if I need to be looking at certain areas of my configuration.
I'm trying to "refine" my engine setup. Which is pretty good the way it is but... I think certain things can still be better. I may have to be going into the motor again anyway because of an oil pressure issue that my gut tells me needs to be addressed. Even more so since having driving TJ's CSL that has the same oil pressure gauge and his seems to be running at least double the pressure of mine. I didnt see his dip below 40 psi. And mine is rarley above that. Just doesnt seem right.
I've been trying to tell myself it's okay. But I drove in the heat a while back while going to visit TJ and it was just to low. And I've got to much into it at this point to not go in and have a look.
