decoupe
(deceased)
Brilliant! From jmiller off the forum at 2002faq.com
http://www.aircooledtech.com/tools-on-the-cheap/soda_blaster/
corsachili said:Speaking of soda blasting, I've been looking for the right way to strip the Alfa that I'm doing for Chel and have been considering soda blasting as an alternative to plastic media, paint stripper, and sanding. I have read about some concerns with soda blasting that are little more than opinion and random reports from unverified sources but apparently the soda leaves a film that must be washed off before priming. Apparently the film will prevent the primer and subsequent coats of paint from adhering. One of the solutions that I heard of was essentially hosing the entire car off with a high pressure washer, something that seems like a very bad idea with bare metal. Plastic media is problematic as well. I have two friends that have had their cars plastic media blasted and the stuff rained down out of every nook and cranny for months after reassembly. Not exactly a desirable outcome for a newly restored interior. Paint stripper is an environmental and health disaster, and using a sander can put a lot of heat in to the body panels, which is not an optimal solution for keeping everything straight. What's the common wisdom regarding the best way to take a body to bare metal prior to paint?
corsachili said:Plastic media is problematic as well. I have two friends that have had their cars plastic media blasted and the stuff rained down out of every nook and cranny for months after reassembly. Not exactly a desirable outcome for a newly restored interior.
