gwittman
Is the failure of a hood support arm a common occurrence at the age of these cars? Yesterday mine broke off near the weld that ties it to the tube the runs under the hood. I took everything apart to see if it can be repaired by welding. Upon inspection of the arm on the other side I found it is cracking and is in the process of failing also.
If this is not a common occurrence then I expect it may become one as these cars get older. I suggest inspecting these arms near that weld area. Welding a crack is much easier than one that has completely broken. I do think mine is salvageable but the tube is not very thick and will take a good welder to repair.
