Horn plate adjustment
Bwana
Santa Fe, NM
Is there an adjustment to set the depth of the horn plate via the three hold down screws? If I screw them in tight (I haven't) I think the horn would blow all the time. You can see the gap between the plate and the steering wheel base in the photo. The way they are now, the screws loosen up over time and I have to take it apart and re-tighten them. What is the proper procedure?
Jeff,
Gap should be 5mm or so, I have the same CSi wheel.
Thanks, on my "to do while sitting out the hurricane" list. Did you do anything to secure the screws? Blue Locktite perhaps?
